Fatal Swan
- Feedback
- View
The bike I bought (2005 Principia Ellipse) had, or quickly developed, a missing M3 hanger bolt and after replacing it I found that the bolt wouldn't tighten, I assume since the tiny thread was damaged. Fortunately the damaged thread was teh one on the hanger and not the frame so off I went to gearmechhanger.com for a £27 (!) replacement:
Tightening up the same bolt (the bottom one in the photo below) with little torque - i.e. using the long end of a tiny allen key - immediately stripped the hanger thread. The company are sending me a replacement but clearly this is an issue in the hanger design - the thin aluminium back plate which the screw threads into can't be more than a couple of mm thick, maybe with 2-3 turns of thread at most.
So the question is, how can I stop it happening again? I don't know how sensible it is to use blue threadlock with such small headed bolts - I guess they could easily get mashed trying to remove them. I don't know if the metals are suitable for threadlock (the bolts are steel, the hanger aluminium), or whether I could even torque the bolt up enough for it to be effective? One idea I had is to buy a longer bolt for the hanger, say with an extra 5mm on the end that would stick through the back, and then attach a steel M3 nut against the back plate, to take some of the burden off the tiny aluminium thread of the hanger. But I have no idea if that would work?
But now I think of it, I guess I could have just used a longer bolt and a nut on the back even on the old hanger with the stripped thread (and saved myself the £27!)...
Any advice please?
Any advice please?
