Specialized M2 Info Thread/Serial Registry
I’ve got this ‘92 frame that I’ve yet to build up ….
Not sure if this has been repainted but was purchased as a low mileage frame….
Not original, but old style decals — makes me think someone has mixed OEM decals from different years, or an eBay edition sticker pack. TT and DT logos are correct font but wrong proportion. Chainstay M2 logo is the 94+ type, not the fancy military font logo that it originally had. I wouldn’t doubt it originally being a Team Red S-Works though — maybe the paint was somehow obliterated by the late 90s and this was the best the owner could do to restore it?
I purchased this frame at the end of last year in northern Italy. I initially identified it as a 93-94 M2 but the paint scheme is special. The previous owner told me it was the official bike of an MTB team from Biella, Team Zola. The team was sponsored by specialized and Zola itself was one of the first specialized dealers in Italy from 1988. The paintwork and decals are the S-works division one but the production number (90T00074) suggests this is one of the very first frames produced in 1990.
I've been trying to better identify the frame but right now I'm stuck with the investigation. I hope someone has some info about it.
For now, the only hypothesis I can make is that the frame was Unsold or archived (I've seen this practice with early production numbers in many bicycle manufacturers) and later issued for this small team in Italy. Or maybe it was aesthetically renewed for the team, this hypothesis does not convince me because I don't see the point in changing not just the decals but also the colour with a complex chromed finish.
Another thing to note here is that the fork is a 1993 model Future Shock, and appears to be 1” threadless. It would have likely come with a steel or aluminum (Kinesis?) rigid fork, or maybe an early prototype of the 1992 Future Shock (like the black/orange/yellow one shown in a catalog). My opinion: source a gold 1992 Future Shock and use that. Build kit wise, it was probably equipped with XC Pro.
Hi all! I would like to share my accumulated knowledge of Specialized’s M2 (Metal Matrix) frame lineup from 1991 to 2000. I will also include a serial registry here to help me (and others) better understand date and color differences between years and trims that may not be entirely obvious. The serial number format I will list below. The M2 frames are relatively common, but there were many differences over the 10-year production run, and I would like to help others ID their M2 bikes more easily, as it is not always obvious when referencing the available catalogs.
1991
The only models offered for 1991 were the Stumpjumper M2 and Stumpjumper M2 Team. The base model was equipped with Deore DX, and the Team model was the same frame equipped with SunTour XC Pro. Both are rare, with the Team being virtually nonexistent. I only have four pictures of 1991 Team’s, including one catalog picture. The base model was metallic pink with red and yellow decals, and the Team had the same color decals with metallic champagne paint.
1992
The only models available in 1992 were the S-Works M2 bikes. This included the S-Works M2 (black with gray/red decals), the S-Works M2 Pro (metallic pink “Purple Haze” with pink and yellow decals), and the limited run of 500 Team Red frames built in honor of Ned Overend’s race-winning bike. The difference between a 1992 and 1993 Team is in the frame’s seat collar — the 1993 collar is rounded in shape, the 1992 collar has squared off edges.
1993
For 1993 the S-Works name was dropped (except for the red Team) and the models offered were the base Stumpjumper M2 (tba) and the Stumpjumper M2 FS (purple/dark green metallic with yellow decals).
1994
1995
1996
1997
1998
1999
2000
Known one-offs:
1995 tri bike, 1996 S-Works M2 base, 1996 S-Works M2 single-speed
Special editions: 1991 Zola, 1996 Olympic, 1998 Bart Brentjens
Seatpost size varied among frames. 1991 to 1993? frames take a 26.8mm seatpost, 1994 frames take a 27.2mm seatpost and frames made from 1995 to 2000 are made for 30.9mm seatposts.
Headset size also varied. Until 1994, all M2 frames had 1” headtubes. The 1994 S-Works rigid model (and the base M2?) retained the 1” headtube, but the other models had switched to 1 1/8”. By 1995 the 1” size was gone from the lineup.
Frames made from 1991 to 1994 used straight-gauge M2 tubing. 1994 S-Works models introduced butted M2X tubing and double-butted M2XX was first used in 1996 on S-Works models.
I will update this post frequently as I dig through my images archive and see what I can add.
The first two digits of the serial number denote the year of manufacture (e.g. 96 = 1996). There seem to be some discrepancies (my 1991 bike is stamped 90), but it is mostly consistent with the model year. The letter indicates model. A similar format was used on FSR models of the time period. From what I can gather, S means Stumpjumper and SW means S-Works. The last several digits seem to indicate the production number.
Feel free to post your bike and I will add the serial to the list. If not posting pics, include the original color scheme (if possible) and frame size. For privacy reasons, only post frames or bikes you own or have previously owned, unless it is a noteworthy contribution, like a unique crossover year model or a one-off.
Serials:
1991 Stumpjumper M2 Zola Team, 20”? — 90T00074
1991 Stumpjumper M2, 18” — 90T00651
1992 S-Works M2 Pro, 21” — ?
1992 S-Works M2 Team, 18”? — 92T1744-6 L
1992 S-Works M2 Team, 18” — 92T2735-6 J
1995 S-Works M2 Road, ?” — 95?
1995 Stumpjumper M2 FS, 18” —
1996 Stumpjumper M2 Comp FS, 17” — ?
1996 S-Works M2 (one-off) — 96S?
1996? S-Works M2 single-speed (one-off), turquoise — ?
1997 Stumpjumper M2 — 97S?
1998 Stumpjumper M2 Comp, 15.5” — 98S4M14332 L
Hey Neko.
I believe this is a 1995 s works. I have the original Manitou sx ti fork. Any idea the value of this?
Hi, this is my 94? M2 Road. Love this bike very much. Stiff as anything and super fast
Hey Neko.
The original fork would have been a Judy FSX Carbon which came with the frame. It is a 1995 M2 Super.
Thank you!
Thanks so much for your reply. Are these still sought after or worth anything?
The FSX forks?! Heck yeah! The bikes… well, yours is a bit rough, but being an S-Works increases its value substantially, and it’s got some sweet parts on it. If you wanna sell it, throw it up locally for about $350, or 280 pounds .07 ounces (or however British money works). Or mail it to me for free 😉
