Retrorockit
I got my Wide Narrow chain rings form China. I got a few sizes in case the chainlime shifted. Also IDK what I really need at 70yo.
It's together and running. Switching to the square taper BB was easy. The freewheel needed a BB locknut for a spacer, but also needed to be all the way on the crank to clear. It took a couple tries but it actually fit, which doesn't always happen with things like this. Chained it up and went for a ride. Nothing seemed different. Oh yeah I forgot to add the magic zip tie between the cassette and spokes to soft lock out the rear freewheel. Now it's working. The W/N ring and 11s clutch derailleur seem to keep the chain on. I'll add the recumbent Idler chain guide anyway because the freewheel is a single speed part and noy intended to have side loads on it's single ball bearing. I'll get some photos up, but it looks much like the vinatge XT stuff I ttok off.
TBH this might not be worth doing on just a pedal bike. But for mid drive Ebikes, or technical offroading it has a lot to offer. Hub Motor Ebikes are on the menu now too. Not very retro stuff for the most part. But FFS rides again.
One thing is the freewheel clicks at crank speed now instead of wheel speed. If it's too fast or too slow you know you need to shift.
